Inventor Forum
How to delete all the camera setting for various sequences in *.ipn file
6 REPLIES 6
lis_wang
387 Views, 6 Replies
I set the various camera view in different sequences but I found it very messy. Now I want to delete all the setting and reset the camera. How shall I do that?
6 REPLIES 6
admaiora
in reply to: lis_wang
Hi Lis,
try this way:
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
lis_wang
in reply to: admaiora
Thanks for your reply. However I know this is the way to set the camera view for each sequence. After I set differrent camera views for all the sequence, I aminated it and found I should not make so many camera view. So I try to edit all the camera view forthe  various sequences to be the same as the first sequence. When I select the sequence to edit, the screen always moves to the camera view I set previously which I want to change now. I do not know how to edit sequence's camera view to be the same as the previous sequence.
admaiora
Hi Lis,
i understand your case.
Try,before set your Camera, right click and you can use Previous/next Views
I hope that it can helps you.
Admaiora
lis_wang
I tried just now. But my previous view is not the previous sequence's camera view.
admaiora
You can use it many times. It can be a little tricky to find your view, but it's the only way i know.
Admaiora
lis_wang
No matter how I tried, I cannot find just exactly the 1st sequence camera view as both home view and previous view are not my 1st sequence camera view. Thanks for your help.
Technology Administrators
