I set the various camera view in different sequences but I found it very messy. Now I want to delete all the setting and reset the camera. How shall I do that?
Hi Lis,
try this way:
Admaiora
Thanks for your reply. However I know this is the way to set the camera view for each sequence. After I set differrent camera views for all the sequence, I aminated it and found I should not make so many camera view. So I try to edit all the camera view forthe various sequences to be the same as the first sequence. When I select the sequence to edit, the screen always moves to the camera view I set previously which I want to change now. I do not know how to edit sequence's camera view to be the same as the previous sequence.
Hi Lis,
i understand your case.
Try,before set your Camera, right click and you can use Previous/next Views
I hope that it can helps you.
Admaiora
You can use it many times. It can be a little tricky to find your view, but it's the only way i know.
Admaiora
No matter how I tried, I cannot find just exactly the 1st sequence camera view as both home view and previous view are not my 1st sequence camera view. Thanks for your help.
