Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How to create a view detail 1:1 in a drawing - I create views in Assembly but don't appear the same in a drawing
evalero7SMX9
evalero7SMX9
Hi
I have 2 questions:
-How I can create a view detail 1:1 in a drawing without having another view in the drawing?
-I have created views in Assembly but when I open as base view in a drawing doesn't appear as I create the view appear as per the Master.
can some one help me, Thanks in advance.
Cadmanto
What version of Inventor are you using?
When you insert your first view into a drawing, which is to your first sentence, there are no other views on the drawing.  You can in the edit view window choose the scale as shown below.
The only time you cannot automatically change the view scale is when the view is linked or associated to another view, but that box just above the scale selection can be unchecked giving you the ability to change it.
Beyond this, if this doesn't answer your questions, we will need more of an explanation of what you are trying to do.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
swalton
Detail Views on Inventor drawings require a Base View.
You can place that Base View outside of the drawing border if you don't want it visible when the drawing is printed.
Steve Walton
Inventor 2024
Vault Professional 2024
johnsonshiue
Hi! I am sorry I don't fully understand the questions. You can copy and paste a drawing view. Or, you change the scale factor like Scott mentioned here.
Regarding the assembly view, I think you are talking about the view direction, right? At the moment, Inventor drawing view does not honor the Design View direction. It is still based on the ViewCube direction or the pre-defined origin direction. To use a custom view direction, you will need to click on the downward button under the ViewCube when placing the view. You will be able to adjust the view direction.
Many thanks!
Software Test Engineer
