Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
Migrating from Inventor xxx to Inventor 2020, issues with mapping screw library
3 REPLIES 3
benboubaker
475 Views, 3 Replies
year after year or user to user, the same problem with screws that are not resolving in the assembly,
i need now and forever to fix these issues, i don't think my company is paying me to spend hours to resolve hardware library every time Autodesk decide to upgrade Inventor every year,
how to migrate properly from Inventor XXX to the latest Inventor with the automatic resolved hardware when i open the assembly?
Thank you,
Adel
3 REPLIES 3
andrewiv
in reply to: benboubaker
Are you talking about content center hardware or do you have your hardware stored in a library folder somewhere?
Andrew In’t Veld
Designer / CAD Administrator
benboubaker
in reply to: andrewiv
The default Autodesk hardware Library, screws, washer etc...
johnsonshiue
Hi Adel,
The first thing you want to do is to make sure the Library paths are correctly defined in the project. Close all Inventor files and go to Get Started -> Project -> look at the lower panel. Are the Library paths properly mapped? Under the Folder Options, where is the CC folder path set to? Make sure it points to where the migrated CC components reside.
Many thanks!
Software Test Engineer
