How to create a joggle at a flange joint?
tuaphan123
tuaphan123
I've been trying to create a joggle feature in Inventor Sheetmetal similar to this article: Wayne Massey - Experimental Aircraft Builder's Log
I've seen people creating simple joggles using a 0 degree flange or an offset face, but I haven't been able to create a joggle that incorporates a perpendicular face like in the article, or at least one in Sheetmetal that unfolds properly.
Any ideas/suggestions?
Thanks!
cadman777
Please clarify.
Is this the joggle you're talking about?
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
tuaphan123
Hi, please see this video.
The joggle I'm trying to do is similar to that except there is a face perpendicular (ish) to the joggle face - like in the original article.
cadman777
Nice video...so this looks like a standard sheetmetal joint in all kinds of fabrication.
So maybe it's something like the attached files?
My Inventor is older so maybe there's a better way to make this in the newer versions?
If there is a simpler or better way, someone else in here can tell you how.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
JelteDeJong
At our company, we use the flange command to create joggles. Just create a flange as usually but set the angle at 0 degrees. Then set the check the box for "Old method" and you are done.
Jelte de Jong
Blog: hjalte.nl - github.com
