In Inventor 2017, when using the shortcut F6 in the 3D modeling environment, an isometric view is obtained with the Z axis pointing upwards. This is not the case with my new version 2019 (Z axis points horizontally).
Question: Where can I set the orientation of the Z axis in an isometric view obtained with F6?
Thank you.
Look at the Viewcube and right-click on the Home icon and select "Options".
Here you can change the orientation to what you require.
Start a new file to see the result.
Cheers
Jon.
