How to close this gap
Julie-Tang
Message 1 of 8
Julie-Tang
Hi all, I was wondering how you would best close  this gap area highlighted here in the screen shot
I tried to add a 45 deg flange on the vertical edge and then a corner seam  but it wasn't turning out how i hoped.
or would it be better for me to draw a seperate piece then assemble it?
Any help is appreciated, thank you
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
Can you sketch on the screen what exactly you want to achieve?
Kacper Suchomski
Message 3 of 8
Julie-Tang
something like this screenshot, without the top corner poking out
ideally would like the bottom corners to meet at the same point
Message 4 of 8
Julie-Tang
file
Message 5 of 8
Julie-Tang
ipt file
Message 6 of 8
BDCollett
Something like this?
I created two work axes, then a plane to establish the location of the new face. Then Corner Seam to finish.
Message 7 of 8
Julie-Tang
Would you mind sharing the file, so I can see the steps to how you did it. sorry I’m not the smartest from just reading
Message 8 of 8
BDCollett
I created this in 2025, if you have the latest patch for 2024 you should be able to open this.
