Inventor Forum
How to change the default settings for Pattern Component
3 REPLIES 3
fsdolphin
474 Views, 3 Replies
Is there a way to change the default 4ul to 2ul and possibly the angle from 90 to 180 in the circular pattern?
The main thing I'm interested in changing is the quantity (4ul to 2ul), the reason is because if you don't put attention and do a 180° circular pattern without changing the qty you endup with four instances in the exact same location instead of 2 and this will be reflected in you BOM if you create one.
3 REPLIES 3
mcgyvr
in reply to: fsdolphin
Nope.. Thats hard coded into the software..
Just pay attention..
fsdolphin
in reply to: mcgyvr
Thanks.
Keith_LacourFLP9X
in reply to: mcgyvr
It's now 2024 and I'm running Inventor 2023. Can we update the default pattern parameters yet?
