HOW TO CHANGE A PARTS X,Y,Z PLANES
I opened up a part file from an assembly file I received from one of our vendors. I need to do some modifications to the part. When I open the part file the object is orientated/created on different work plans then the standard work planes in inventor. Is there a way I can change the parts xyz planes to match the standard xyz work planes in inventor?  Attached is a picture
swalton
Use the "Move Bodies" command.  Use the measure command to see how far you need to move/rotate the body.
Steve Walton
Inventor 2025
Vault Professional 2025
Thanks! This worked. I was aware of the part move option, but did not know about the translate and rotate options on the left side of the window.
JDMather
You can also use Direct Edit
