Render an imported .obj
wouter
wouter
Hi all,
I'm having trouble rendering an imported .obj file.
In inventor it has colors, but when i trie to render the part it loses all colors.
Does anyone have a solution or tips to look at?
I attached the part to test on.
Thank in advance
Wouter Vrouwenvelder
Marco.Takx
Hi @wouter,
For one reason I don't know yet is that an OBJ imported file lost his appearances.
I found a workaround to render your model.
I saved your model as a STL file and imported it again.
Then I was able to render your model (See below).
I've also attached the model again (STL file that I imported again).
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
wouter
Hi marco,
I always told saving it as STL would actually lose it's appearance, guess i was misinformed.
Thank you for the model.
Greetings,
Wouter
