Inventor Forum
How to calculate pipe length for imported part
9 REPLIES 9
Message 1 of 10
AIR_123
462 Views, 9 Replies
Guys,
I have imported structure made with frames.
How can I estimate / capture pipe lengths to add to BOM?
Bellow is example of one member. It is curved. I need to know cut length of it.
__PRESENT
9 REPLIES 9
Message 2 of 10
CCarreiras
in reply to: AIR_123
Hi!
Edit the part
Create a sketch
Create an arc between the cut points.
Mesure the arc lenght.
Something like this:
CCarreiras
Message 3 of 10
Secttor
An alternative could be.. based on the middle-radius (which I assume you can reach it)..Larc = (πR)/180
n° = angle of the arc (degrees)
R = radius (middle)
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 4 of 10
AIR_123
in reply to: CCarreiras
Ok, thanks.
What if standard planes are not section beam through CL?
Message 5 of 10
CCarreiras
Well, if it doesn't exist, you have to create it:
CCarreiras
Message 6 of 10
AIR_123
OK cool, thanks. I was not aware IV will recognize midpoints of the curved edges.
Message 7 of 10
AIR_123
Is automation of complete process possible?
Message 8 of 10
CCarreiras
All you can do manually it's possible to automate... but the problem is... the inputs you will need!!
In this case, how does the software know which points you want to create the plane? You will have to tell it to the software, so... the automation will take the same work as doing it manually.
CCarreiras
Message 9 of 10
AIR_123
@johnsonshiue
how would you capture the length of "out of plane" bent pipe in this case? Any tricks you can offer?
maybe you guys (AD) can consider to add one of the options below to IV?
- possibility to estimate virtual CL length of the curved pipe?
- possibility to unbend pipe similar to  sheet metal flatten?
- possibility to automatically create construction geometry (planes/UCS) through CL based on bounding box?
__PRESENT
Message 10 of 10
johnsonshiue
Hi! The only alternative workflow I can offer in this case is using a simple math. Get the volume from the physical iProperties. Use it to divide the cross section area. This will give you the length of the pipe. But with the special cutouts at the both ends, this approach may not work precisely.
Regarding the request, I believe I have seen it before. Please feel free to submit it to Inventor Ideas forum or vote for a similar one.
Many thanks!
Software Test Engineer
Technology Administrators
