Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to bend Flange along sheet fold?
hello,
Please check attached File and photos (oven)
Flanges runs along sheet fold.
How to make this in Inventor 2015?
Thanks.
t_hascj
Did you try Bend Part command? See video. But there is disadvantage that from this part is not possible create Flat Pattern.
Jaroslav
This is deepdrawing a metal sheet and as such not a job for the plate shop but requiring heavy machinery. Similarly in CAD : you can model it - starting with the outside volume, followed by shell - but it won't flatten. If the purpose is modelling then do it in Part.
johnsonshiue
Hi! You could use regular part modeling commands to create the geometry. The issue is that the part will not be unfoldable.
Many thanks!
Software Test Engineer
this is not bending its forming .you have to make special punch tool create your shape.
Any  bending which is practically not possible on the bending machine same we don't won't create in sheet metal.
check how to make puch tool link.
https://www.youtube.com/watch?v=KmZp3ZsU-6o
