How to assemble a round object in between pillars on a horizontal surface
Message 1 of 12
HI , i am trying to place (assemble) a round object in between 4 pillars on a horizontal surface, can anyone help which constraints i can use to fit it right in the centre of those 4 pillars?
regards
Replies (11)
Message 2 of 12
JDMather
I would use a Mate and a Tangent constraint (judging from your picture).
If you want precise solution - Attach your assembly here.
Message 3 of 12
Cadmanto
Depending on how you have created your tube, if you have planes going down the center, you could constrain the plane that goes the length with the plane that hopefully goes down the length in the center,
then tangent the tube bottom to the plate and then the plane that cuts through the tube to the plane that cuts across the center of the plate.  What I am suggesting is simple, but it all depends on your design intent.
Hope this makes sense.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 12
Frederick_Law
Every part has 3 planes and 3 axis.
Use them.
Message 5 of 12
Thank you for your reply JD Mather, attached is the assembly.
regards
Message 6 of 12
Thank you very much for your reply Cadmanto,  i will try to follow the procedure which you mentioned.
regards
Message 7 of 12
JDMather
regards
An assembly must include parts to be an assembly of parts.
Attach your *.ipt files here.
Message 8 of 12
Dear JDMather, attached are ipt parts
regards
Message 9 of 12
Select Ground and Root from the productivity tab, check the ground at origin box, then select your base plate.  This locks your base plate to the origin of the assembly.  Then (using the work features in each part's Origin folder) constrain the X axis of the casing to the XZ plane of the base plate.  If you want to clock the position of the casing, select the angle constraint and use the origin planes of each part and assign the relative angle.
Message 10 of 12
JDMather
Your threaded holes are the wrong size.
What is the tap-drill size for an M15 thread?
What will happen if you attempt to assembly an M15 fastener into a 15mm drilled hole?
(There are other issues as well.  Is this a school project?  Would you like to learn how to use Inventor more efficiently?)
Message 11 of 12
IgorMir
Hi Jeffrey;
Besides - while M15 thread is listed in the Thread DB in Inventor - I yet to see fasteners with M15 thread. Be it normal pitch or a fine one.
Cheers,
Igor.
Web: www.meqc.com.au
Message 12 of 12
Dear JD Mather
It is just a school project and i am not going to build it without the mechanical workshop consultation, so the basics of Inventor will be more than enough for me at the moment.
Thanks for your reply.
regards
