How to align with the Orthobox
ona001H2M7Y
ona001H2M7Y
There is a problem regading this. i don know i to align, somehowe my assembly got tilted so it isnt align the the ortho
blandb
Is your model aligned to the assembly origin? If it is, then was the view cube changed to set this current view based on a front/right, etc?
Autodesk Certified Professional
johnsonshiue
Hi! Try constraining the parts to the origin. Please share the files that exhibit the behavior here. I would like to understand the issue better.
Software Test Engineer
ona001H2M7Y
I cant show for now, sadfully... because i just choosed to start from assembly from skratch... i couldnt find a solution.
but when i used the view on the box at the right corner as the shown in the picture. i saw that the whole assembly was tilted. and i couldnt figure how to fix it
ona001H2M7Y
Idk if my model is aligned to the assembly origin. but the cube was straight.. Like the cube is straightor aligned. but it was my assembly that was tilted
ona001H2M7Y
you can see on this picture that the part is aligned. with the box, and not tilted like before. sadfully i had to assembly the whole thing to get to this point again
