"Save and replace" Save session edits??
b_ruijter
b_ruijter
Somehow the "Save and Replace" command triggers a change in the original file.
Could sombody tel me how te turn this off??
johnsonshiue
Hi! Is there an iLogic rule running behind the scene? The behavior does not look right to me. If possible, please share the files in zip with me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
b_ruijter
Hello John, thanks for your reply.
I tested it with our ilogic triggers shut down, than it does not gives the changes to the original file.
We only trigger on
-New document
- Before save document
- Material change (only for parts)
I do not understand why or how it should affect the save and replace action.
I've send you all the files that are involved.
Hope you can help!
I've send you all the files that I'm using in this video.
