Hi guys,
We have had to do some testing on a bunch of Inventor PC's recently to determine which of the PC's needs to be replaced. Obviously we needed to find out which of the PC's are the worst eprformers as there was only budget to replace 50% of the design PC's. So we thought the Darwin theory will come in handy right... 🙂
Anyways I started searching on the net for toppics on how to benchmark an Inventor PC. Then I thought whats the point of using gaming benchmark tools because Inventor is not a game and there are more aspects than just graphics performance when it comes to percieved performance on an Inventor PC right.
So we decided to create our own Inventor benchmark tool which tests various aspects of an Inventor PC to give us an overview of our PC's performance. This then helped us make a decision as to whcih pc's to replace.
We have made the tool available free of charge to anyone interested in checking how their PC stacks up to their peers or friends. 🙂
Please download it here and post your results here as well if you want. Would be interesting to see what beast workstations are out there.
I would like to say thanks to Kirk #karthur1, for helping in testing the app.
Please feel free to send any suggestions our way. There is an email link in the app.
The application will work with Inventor 2014 to 2016 only.
IMPORTANT: After installation there will be an Inventor Bench icon on your desktop that looks like this:
My resluts:
HP Elitebook 8560w with an SSD upgrade.
Solved by Neil_Cross. Go to Solution.
Solved by Raider_71. Go to Solution.
Correct but why is it listing it first. Not that I'm complaining about the score was just curious if that was hindering the score.
@phlyx I've just noticed your Intel XTU score. 100c is scorching hot and a 9700k normally should turbo up to 4.9GHz,
where as you are only hitting 4.1GHz.
What are cooling that processor with?
At 100c your processor will hit tjunction causing it to thermal throttle. Look at a bigger cooler.
Water cooling isn't needed but a beefy heatsink maybe a good resolution.
It shouldn't unless you are writing to it.
Check disk management (win + r, diskmgmt.msc) and see what order the discs are in.
@bwatson1967 On Phlyx's temps?
Their max XTU temp was 100c
What are you cooling your CPU with?
My concern was with Phylx is that the XTU benchmark is not a sustained or 'burn in' benchmark which means the processor shouldn't get that hot.
@bwatson1967 What cooler is on your processor?
Your 55c is the same as mine at idle.
If Phylx is also on a laptop with just a cooling pad then that would explain. 9700k is a desktop class processor rather than a mobile class processor, mobile class processors tend to run a bit cooler due to limited cooling capacity (also slightly slower so less heat).
That's a really good score; yeah, I noticed that IV Bench doesn't always report the correct OS drive (Neil probably knows more about that than me). But if you do have any external drives, memory cards, etc. plugged in, it would interesting to see you redo this test with everything unplugged (except the OS drive-LOL).
I do not have any other drives plugged in. Its a pretty consistent score every time. Just ordered a MSI desktop with liquid cooling that has all the same components and it dont score that high.
It's only recent that Nvme's became close in price to SSD's of the same capacity. Of course I would always buy the Nvme with those prices being the same (because they're never slower). Is it faster? In benchmarks, absolutely, in real-world performance, absolutely not, especially by any appreciable/noticeable amount (for most uses; CAD work, Office programs, browsing the Internet). I have both, I use Userbenchmark.exe (google it) to test my PC's for general use and IV Bench for CAD benchmarking. I can see a proportional increase from my i7-8700k (work) to my i7-6700k (home) and apply that ratio to my IV Benchmarks to see if they increase by a similar proportion (they always do). If you really want to go fast (faster than any Nvme can hope to be), you can dump your Windows appdata folder to a ramdrive and set up some symbolic links to it; you will BLOW AWAY all Nvme drives. I used to do this, but the image file took too long to save back to the drive upon shutdown and the appdata folder was not getting properly updated (too dynamic), so I stopped doing it (proceed at your own risk).
Phlyx is running a workstation. Identical to mine in everyway save login and desktop wall paper. My Machine will consistently benchmark about 1 to 2 points higher than his. Here's the last bench mark I pulled on my machine. Save time sucks as well.
Phlyx's Co-Workers Benchmark
@RNDinov8r What is the max temp of your WS?
If you can try running an XTU benchmark as that gave us a max temp of 100c on Phylx which is awfully hot.
Where is your computer located? (Is the airflow restricted?)
So,
here's my result after running XTU. Mind you I had nothing running at all when I ran this. Phlyx was running Inventor Bench...however, I will run Inventor Bench, so we have apples to apples.
Here's my result while running XTU during an Extensive IVBenchmark. Overall, decrease in IV performance but, Processor did well. That being said, it still doestn' explain our save times...which are insanely high.IV Benchmark while Running XTU
2nd XTU test
@RNDinov8r That is massively better than Phylx, So I suspect cooling as you're 21c cooler and .5GHz Faster.
