Hi guys,
We have had to do some testing on a bunch of Inventor PC's recently to determine which of the PC's needs to be replaced. Obviously we needed to find out which of the PC's are the worst eprformers as there was only budget to replace 50% of the design PC's. So we thought the Darwin theory will come in handy right... 🙂
Anyways I started searching on the net for toppics on how to benchmark an Inventor PC. Then I thought whats the point of using gaming benchmark tools because Inventor is not a game and there are more aspects than just graphics performance when it comes to percieved performance on an Inventor PC right.
So we decided to create our own Inventor benchmark tool which tests various aspects of an Inventor PC to give us an overview of our PC's performance. This then helped us make a decision as to whcih pc's to replace.
We have made the tool available free of charge to anyone interested in checking how their PC stacks up to their peers or friends. 🙂
Please download it here and post your results here as well if you want. Would be interesting to see what beast workstations are out there.
I would like to say thanks to Kirk #karthur1, for helping in testing the app.
Please feel free to send any suggestions our way. There is an email link in the app.
The application will work with Inventor 2014 to 2016 only.
IMPORTANT: After installation there will be an Inventor Bench icon on your desktop that looks like this:
My resluts:
HP Elitebook 8560w with an SSD upgrade.
Solved by Neil_Cross. Go to Solution.
Solved by Raider_71. Go to Solution.
Nice, do we have a leaderboard for this thread?
Nothing official but I've kind of been keeping a list personally. It's a bit out of date though.
Check out this dinosaur.... HPZ600 workstation.
I remember calling into Autodesk a while back to ask a technical question about something and the guy on the other line remoted into my computer, looked at the specs, and was astonished at how we were even still using these computers.
Can we get a bench of who can get the lowest score?
I just happened to add a few low scores to my spreadsheet also. You've been "beat" by a few different pcs before.
Hey so... does anyone have the download link handy? The openingspost does contain a link but its not working anymore.
I realised that I haven't benched my home PC yet.
Edit: never mind, it's in the Autodesk Store:
At 1920x1080
At 2560x1440
At 2560x1440 with Performance mode.
Note my Cdrive is an SSD but I have multiple drives so the bench doesn't see itright.
___________________________Jeez, a 0.38 is so low, what config was that?
New to forum, I use Inventer for work and decided to get in on home PC I just built. Not sure how the scoring system works but looking at other posts it seems ok. Anyone else having trouble with stutters or hitching when modeling? it occurring when using a 3d mouse to rotate model.
Specs:
MB: MSI B450 Gaming Pro Carbon AC
CPU: Ryzen 3600, with PBO enabled
Cooler: Coolermaster Hyper 212 Black edition
Ram: 16gb Corsair LPX 3000mhz
GPU: Founders Nvidia RTX 2070 super
HDD1: SATA 1tb Samsung 8 860 SSD
HDD2: SATA 500gb WD blue SSD
PSU: Corsair RM750 80+Gold
Case: Coolermaster Mastercase H500 with mesh front panel
Well, since there's a leader board now, see below. Still OC'd / environment variables and Inventor Undo file point to RAMdrive.
Very good score, 3rd place for now, I'll be interested in seeing whether AMD can make a high impact.
Awesome!. How big is your ram disk? Is setting up the undo file to a RAM disk a permanent setting that improves the performance or you just did it temporally to get the score?. Just wondering if I should do the same.
@leowarren34 wrote:Very good score, 3rd place for now, I'll be interested in seeing whether AMD can make a high impact.
Thanks. I personally stay away from AMD because of their lack of driver support out there.
@Mario-Villada wrote:Awesome!. How big is your ram disk? Is setting up the undo file to a RAM disk a permanent setting that improves the performance or you just did it temporally to get the score?. Just wondering if I should do the same.
Thanks! RAMdisk is 11GB (but I also use it for Internet cache and other things). Yes, my undo file is permanently in RAM because Inventor mirrors your every move (so to speak). I also completely disabled all page/swap files even though Autodesk recommends using a system-managed pagefile (that was never faster; at least set MIN & MAX equal if you do that). BTW-all RAMdrives are not equally-fast; I've tested a number of them. The best/fastest free one I found is from Qiling Disk Master (I also have all environment variables in RAM which is a one-click option in that utility). And oh yeah, keep Windows updated also...
How About HyperThreading?
We deactivated it... Autodesk recommends it...
any opinions?
I haven't had any issues with Hyperthreading enabled...
Do we have any data on this?
@gunter.stachon wrote:How About HyperThreading?
any opinions?
Never gave it much thought, but I just disabled it and my "rig" was ...0.60 slower in the Inventor Bench app (so I'll keep it on). And I also wonder how they they are the authority on that when their own website is slow af.
Disabling Hyperthreading isn't relevant advice any more, that recommendation was conceived during a time when PCs where still dual core and therefore core availability was at a premium. Now with 6, 8, 12+ core CPUs being pretty normal now, disabling hyperthreading isn't going to make any noticeable difference to anything.
It's old advice which needs to really be archived and taken off all the literature. It's even still being baked into the Application Performance Profiles that you get bundled in with a new HP, Dell, Lenovo etc and marketed as turbo charging your experience or some such nonsense, purely off the back of this old literature being taken as gospel. Basically if you look up what Hyperthreading/SMT actually is, apply that to the number of cores that modern systems have now, it's impossible to draw the conclusion that disabling it will make anything go faster. In fact day to day, disabling it is going to lose you time across the board with other things that you do.
There's possible reasons and arguments to both keep the advice there and take it off, but going over all of that would be a long story.
A leader board you say....
Suddenly feel myself getting far more competitive!
How bad is IPI 1-9,25 ?
#askingforafriend 🙂
Depends really. Overall in context to everything else, it's about average. If you spent £400-500 on the system it's a great score, if you spent £3000-4000 it's pretty terrible. The best ever scores are around 13-15.
