Hi guys,
We have had to do some testing on a bunch of Inventor PC's recently to determine which of the PC's needs to be replaced. Obviously we needed to find out which of the PC's are the worst eprformers as there was only budget to replace 50% of the design PC's. So we thought the Darwin theory will come in handy right... 🙂
Anyways I started searching on the net for toppics on how to benchmark an Inventor PC. Then I thought whats the point of using gaming benchmark tools because Inventor is not a game and there are more aspects than just graphics performance when it comes to percieved performance on an Inventor PC right.
So we decided to create our own Inventor benchmark tool which tests various aspects of an Inventor PC to give us an overview of our PC's performance. This then helped us make a decision as to whcih pc's to replace.
We have made the tool available free of charge to anyone interested in checking how their PC stacks up to their peers or friends. 🙂
Please download it here and post your results here as well if you want. Would be interesting to see what beast workstations are out there.
I would like to say thanks to Kirk #karthur1, for helping in testing the app.
Please feel free to send any suggestions our way. There is an email link in the app.
The application will work with Inventor 2014 to 2016 only.
IMPORTANT: After installation there will be an Inventor Bench icon on your desktop that looks like this:
My resluts:
HP Elitebook 8560w with an SSD upgrade.
Solved by Neil_Cross. Go to Solution.
Solved by Raider_71. Go to Solution.
@Neil_Crossmaybe it's worth trying the driver? I don't have admin on my work machine.
9.18.13.4788 is 347.88 which appears to be an old quadro ODE driver.
http://www.nvidia.com/download/driverResults.aspx/83304/en-us
Well that definitely doesn't make any sense now, your CB score is quite low, so there's no sense in how it could blitz through the CPU based Inventor tests better than any other CPU you see on the chart below.
Here's my chart so far for Cinebench, you scored 694...
Hi @Neil_Cross,
Been watching alot of your videos, has been really helpfull in my new job.
this is my score from my 1 year old gaming rig with my 6600k @4.6GHz.
My boss already asked me to configure 2 new PC's for the office.
A 7700k and 1080 are currently on the table.
Thanks again
Ray tracing doesn't use the GPU, it's 100% CPU. Inventor doesn't use any of the GPU to any great extent other than needing enough VRAM to get by.
How you should justify a card like that is to simply lay down VR as being an option for the future, you will need a big GPU for that.
Convincing my boss is no issue at all, He first planned on the Nvidia P4000 but then i told him that has no real benifit + the lack of HDMI ports would require the purchase of some adapters.
The 1080 is a more powerful card than the P4000.
If you want the best of the best within reason, the 1080Ti is the one to have.
The 11GB VRram could come in handy when working with tons of 3D point cloud data.
___________________________Maybe someone can test his pc with this old nvidia-driver (9.18.13.4788 - from 2014?). Sometimes the system runs feature-apps, which need performance in the background. So an older driver without this is more effective.
On the other hand, some performance needing features of Inventor are not (fully) supported (quality-level of shadows or things like that).
Hi guys,
I added a minor improvement to InventorBench which allows you to set the output folder for when saving the IPT. This has been an issue for some people having set their My Documents folder to a server drive for instance. This will affect your score when doing the model save time test.
You can now specify the folder by clicking the "link label" which is visible just below the "Model Save Time" are on the results pane.
Give it a go and let me know what you find.
InventorBench 2.0 is still in the works...
Cheers!
Just built this new PC, was hoping for 12-13 and getting 11's. Any suggestions on where I should try to tweak anything?
So did you clock anything?
I have a i7-6700 / Asus Strix 1070 / 32 gbs of Ram ...
But I clocked both the CPU and GPU to get my scores...
Sweet PC though.
Yea if you want to win at the benchmark you need to overclock, even the 7700K.
Many people will disagree with me and I'm not gonna go off on one here about it, but I still say and will always say that overclocks should be left at home and only at home, I wouldn't ever encourage anyone to overclock a PC in a business unless it's your business and you own the PC and know the risks.
Stock I was High 11's ...low 12's.
I also killed EVERYTHING in my task manager ...
@Neil_Cross wrote:
Sweet PC though.
I'm with Neil, I only overclocked it for the benchmark test ... I run it normal clocking all day everyday ....
Yeah my home PC (which I also run my own business off) is overclocked, but that's because I'm liable. If it blue screens on me during an encode or a render, I've only got myself to answer to! And it has. It's stable 99.99% of the time, but at full tilt usually on a ray trace it can clock out and retire on me.
