How does Inventor choose a cosmetic thread?
ethan_howardMMXXV
ethan_howardMMXXV
I modeled an internal 1-1/2 NPT thread to the numbers shown below for "Tapered Pipe Thread NPT" but when choosing the cosmetic thread, it jumps to 2" NPT thread. Is there a reason for this? How does Inventor decide, given the thread.xls file, since there is a big dimensional difference between 1-1/2 and 2 NPT? Thank you.
ethan_howardMMXXIV_0-1714142404076.pngethan_howardMMXXIV_1-1714142416386.pngethan_howardMMXXIV_2-1714142427240.png
Autodesk Inventor Professional 2024
64-Bit Edition
Build 272, 2024.2.1 Update - Date: Thu 2/8/2024
Autodesk Vault Professional 2024
Build 29.2.88.0
2024.2.1 Update
Replies (13)
CGBenner
@johnsonshiue do you know the criteria used by Inventor for this?
Chris Benner
Industry Community Manager – Design & Manufacturing
chris
@ethan_howardMMXXV This is a normal thing, IV usually presents the size two sizes larger for me. It's weird, but I've just learned to make sure I choose the right thread size in the dialog
johnsonshiue
Hi! I am sorry I don't know the logic behind it. I need to work with the project team to understand it better.
Many thanks!
Software Test Engineer
CGBenner
@ethan_howardMMXXV Hello, do you still need help with this question?
Chris Benner
ethan_howardMMXXV
Thank you for your question. If I understood how Inventor chooses a cosmetic thread, I could better model such that when I select the surface to be threaded, it would choose the correct thread. Currently, it chooses a larger thread. One person said that it chooses two threads larger. Why such a discrepancy?
Mario.VanWiechen
Inventor does better with convential threads as far as guessing which thread it should be. NPT is very different as you know, 1 inch pipe is 1 5/16 od so guessing becomes difficult it seems
CGBenner
@johnsonshiue Hi, Johnson.  Have we learned anything new about this?
Chris Benner
johnsonshiue
Hi Folks,
I am sorry I don't have any further information. Let me work with the project team to understand it better.
Many thanks!
WillL84
Inventor never seems to guess threads properly lol. It always guesses but for me with standard threads it's ALWAYS at least 1 size too big.
Windows 11 Pro 64-bit
Inventor 2025 (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
yulong_zhang5AYNC
Hi @ethan_howardMMXXV .
After Dev's investigation, from the code design, the thread size by auto-selecting when picking up a conical/cylindrical face follows below rule:
  1. Calculate the diameter of cone/cylinder face (if it is cone, the diameter is the mid diameter)
  2. Choose the larger but closest thread size from the first Type family's group, compared with Thread Nominal Size.
So, for this case, the cone diameter is (1.7106+1.7446)/2 = 1.7276 inch. And larger but closest Thread Nominal Size is 2 NPT. That's the reason. This is by design.
Thanks.
ethan_howardMMXXV
Hi Mr. Zhang, thank you for describing how Inventor works for threading. I appreciate how this community sticks to an issue. Could you tell me why choosing the closest larger thread size is "by design"? Designers ensure threads are modeled correctly by the Machinist's Handbook/standards. It would save a little time if Inventor gave us the correct cosmetic thread. Even if a Designer models the preparation of a drilled or conical hole imperfectly, it is close enough that Inventor should know which thread size to use?
yulong_zhang5AYNC
Thank you for your reply @ethan_howardMMXXV . I discussed with developer. You are right about it, we also thought it should choose the closest size when the drilled or conical hole is imperfect. Developer did some fix. Thank you again for your comments.
ethan_howardMMXXV
Thank you for fixing this Mr. Zhang
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
