Inventor Forum
wont extrude
3 REPLIES 3
fillipluigiferra
99 Views, 3 Replies
wont extrude
hi this wont extrude, im trying to make a skeleton for a frame but it wont extrude, please help
3 REPLIES 3
You need to do this on a part level and place it in an assembly
BeKirra
in reply to: fillipluigiferra
Please try this.
  1. Create a sketch file (IPT). It is also called skeleton when using frame generator.
  2. Insert the skeleton in the assembly file.
  3. Start the frame generator and follow the instructions. It will create individual part files (IPT) for the frame members.
Otherwise, extruding solid in assembly (IAM) is not possible (wont extrude as you mentioned), except cutting off solid(s) in assembly.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
blandb
You cant send just the assembly, we need ALL components that also go with that assembly.
Autodesk Certified Professional
