Inventor Forum
HOw do you make a gear in Autodesk?
11 REPLIES 11
Message 1 of 12
45751 Views, 11 Replies
Does anyone know how to make a Gear in autodesk?
11 REPLIES 11
Message 2 of 12
DarrenP
autodesk is a name of the company
i assume you mean inventor since you posted this in the inventor forum
DarrenP
Message 3 of 12
in reply to: DarrenP
My bad. I ment to put inventor. I have no clue how to make a gear. And i need to make one
Message 4 of 12
JDMather
Start a new assembly file.
Save the file.
Start the Gear Generator ) (Design Tab) and enter the specifications.
Message 5 of 12
coreyparks
in reply to: JDMather
Just so you know, Inventor does not create a true gear tooth profile only an approximation.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
Message 6 of 12
I have drawn the gears, but can u please assist me in locating the centres of the gears so that I can put a hole and key way 4 the shaft
Message 7 of 12
JDMather
Turn the visibility of the sketches on.
Have you gone through the tutorials?
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Message 8 of 12
LT.Rusty
No, he's talking about the second account he's going to have to create if he wants help after the ban hammer teaches him some basic manners when it drops in 5 ... 4 ... 3 ...
Rusty
Message 9 of 12
in reply to: coreyparks
Hi
Can you advise how to make true gear (ready for production) from the design accelerator.
Manjinder
Message 10 of 12
JDMather
You should have started a new thread for this.
Search for True Involute tooth profile.
This topic has been covered here many times in the past.
If your search does not turn up the solution threads - post back and I will find them for you.
Message 11 of 12
Thanks very much for a quick reply.
I found several posts covering this subject. I am able to do that now. But
I have few more concerns. I have to make a gear with helix angle of 20
degree. I have exported the tooth profile from the design accelerator. It
gives me a model with one tooth profile. I just extrude it and circle it to
make a gear. That's all good but I am wondering how to make the same gear
with helix angle of 20. I am trying to wrap my head around this. (I am
trying a pinion gear and an internal gear)
Also, I want to send the information to a custom gear manufacturer to make
this gear physically. I don't know too much technical knowledge about spur
gears. I need some help (study material) or someone's help to finalize all
the technical details to give to the gear manufacturers.
Where can I find such a help. Any help will be appreciated. Thanks a ton !!
Regards
Manjinder
Message 12 of 12
JDMather
@Anonymous wrote:
...Also, I want to send the information to a custom gear manufacturer ....
The gear manufacturer should know more about the geometry than you can know after several months of study.
I recommend that you simply give them the specifications and let them use their experience to manufacture the gears
(if  you don't already know the specifications - that is a couple of weeks of study)
or
better yet,
use off-the-shelf gears if you can.  Much less expensive.
The gear manufacturer should be willing to work with you to arrive at the best solution based on their experience.
What gear manual are you using to learn about gear geometry?  (Author and Title?)
What materials will be used to manufacture the gears?
What type of application and environment will they be used in?
