Does anyone know how to make a Gear in autodesk?
Solved by JDMather. Go to Solution.
autodesk is a name of the company
i assume you mean inventor since you posted this in the inventor forum
DarrenP
Start a new assembly file.
Save the file.
Start the Gear Generator ) (Design Tab) and enter the specifications.
Just so you know, Inventor does not create a true gear tooth profile only an approximation.
Turn the visibility of the sketches on.
Have you gone through the tutorials?
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
No, he's talking about the second account he's going to have to create if he wants help after the ban hammer teaches him some basic manners when it drops in 5 ... 4 ... 3 ...
Rusty
Hi
Can you advise how to make true gear (ready for production) from the design accelerator.
Manjinder
You should have started a new thread for this.
Search for True Involute tooth profile.
This topic has been covered here many times in the past.
If your search does not turn up the solution threads - post back and I will find them for you.
@Anonymous wrote:
...Also, I want to send the information to a custom gear manufacturer ....
The gear manufacturer should know more about the geometry than you can know after several months of study.
I recommend that you simply give them the specifications and let them use their experience to manufacture the gears
(if you don't already know the specifications - that is a couple of weeks of study)
or
better yet,
use off-the-shelf gears if you can. Much less expensive.
The gear manufacturer should be willing to work with you to arrive at the best solution based on their experience.
What gear manual are you using to learn about gear geometry? (Author and Title?)
What materials will be used to manufacture the gears?
What type of application and environment will they be used in?
