I'm am looking to send out a large assembly file that I would like to make uneditable. I just want to people to be able to import the model and using the sizing/geometry of it. I don't want them to be able to break it apart and see the assembly components etc. How do I do this? If I save it as a standard step file is this enough? I've also tried to insert the assembly into a part file as a derived part but my computer freezes every time I try it. Is the assembly is too large to do this? (350 unique parts). I'm running an i7 2600 with 8gb of ram (should be enough power I would think) and Inventor Pro 2010.
Ive used 'shrinkwrap' before to do this... not sure if 2010 has this??
@jameslovell4987 wrote:Ive used 'shrinkwrap' before to do this... not sure if 2010 has this??
It does - 2010 was the release that introduced it.
on 2012....
follow the instructions... it will take a bit of playing 🙂
Thanks, it was right under my nose. The computer still freezes up though 😞 It doesn't seem like my assembly is too large to do this. Is there any other way?
Shrinkwrap can take up a lot of resources even if you consider your assembly "small". You might try a traditional way to do this by...
Open a new Part file
Finish the Sketch
Start the Derive command
Choose your Assembly
Choose Composite type
On the last tab, there are some shrinkwrap options, maybe remove parts that are 10% less of the full size
Don't hole patch
Save out as a Step file
If you get stuck I have a paper on it that I spent some time on. Direct Message me and Ill give it to you if you get stuck.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Just to clear things up, I got it to work. Even though the screen went grey and Inventor said not responding I just left it for about 8-10 minutes and it worked.
Thanks again for the help
...but only works in 2013.
