Inventor Forum
How do you create an uneditable file to send proprietary information?
8 REPLIES 8
Message 1 of 9
1725 Views, 8 Replies
I'm am looking to send out a large assembly file that I would like to make uneditable.  I just want to people to be able to import the model and using the sizing/geometry of it.  I don't want them to be able to break it apart and see the assembly components etc.  How do I do this?  If I save it as a standard step file is this enough?  I've also tried to insert the assembly into a part file as a derived part but my computer freezes every time I try it.  Is the assembly is too large to do this? (350 unique parts).  I'm running an i7 2600 with 8gb of ram (should be enough power I would think) and Inventor Pro 2010.
Tags (2)
8 REPLIES 8
Message 2 of 9
JamesLovell
Ive used 'shrinkwrap' before to do this... not sure if 2010 has this??
James Lovell
Windows 10 Professional (64-Bit)
AMD Ryzen 9 3900X 12 Core CPU
32GB Corsair VENGEANCE DDR4 3200MHz,QUADRO RTX 4000, 1TB CORSAIR MP600 GEN 4 PCIe NVMe
Product Design & Manufacturing Collection
Message 3 of 9
jtylerbc
in reply to: JamesLovell
It does - 2010 was the release that introduced it.
Message 4 of 9
in reply to: jtylerbc
What is the procedure for using the shrinkwrap/where is it located?
Message 5 of 9
JamesLovell
on 2012....
follow the instructions... it will take a bit of playing 🙂
James Lovell
Message 6 of 9
Thanks, it was right under my nose.  The computer still freezes up though 😞  It doesn't seem like my assembly is too large to do this.  Is there any other way?
Message 7 of 9
mflayler
Shrinkwrap can take up a lot of resources even if you consider your assembly "small".  You might try a traditional way to do this by...
Open a new Part file
Finish the Sketch
Start the Derive command
Choose your Assembly
Choose Composite type
On the last tab, there are some shrinkwrap options, maybe remove parts that are 10% less of the full size
Don't hole patch
Save out as a Step file
If you get stuck I have a paper on it that I spent some time on.  Direct Message me and Ill give it to you if you get stuck.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 8 of 9
Just to clear things up, I got it to work.  Even though the screen went grey and Inventor said not responding I just left it for about 8-10 minutes and it worked.
Thanks again for the help
Message 9 of 9
JDMather
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-Simplification-Technology-Preview-available...
...but only works in 2013.
Technology Administrators
