Inventor Forum
How do I turn off an emboss in an idw?
5 REPLIES 5
BKoomler
342 Views, 5 Replies
BKoomler
Today I am making a set of prints for a device I've finished. On the prints I have an assembly view as well as detail views for the parts that require it. On the device one part has been embossed showing where my fabricator will stamp identification numbers. The problem is I want to get rid of the emboss on the detailed part view. Other then making a new layer does anyone know a good way to accomplish this? Not really a big issue but kind of annoying.
Thanks!
Ben
IV 2009 Pro
Thanks!
Ben
IV 2009 Pro
5 REPLIES 5
dan_inv09
in reply to: BKoomler
dan_inv09
Maybe you could expand the part under the view and Right Click the emboss feature to turn off it's visibility. (You'd have to do it for each view.)
BKoomler
BKoomler
Tried that and there is no option to do so.
dan_inv09
dan_inv09
Then pick select as edges then RMB to turn off visibility.
(I didn't notice visibility wasn't there, I had been changing properties so mine wouldn't show up as a little ink blob, I had to use select as edges because I needed to keep some of the lines fatter.)
Have you tried a window crossing of the feature/text in you IDW and
suppressing the visibility. You may need to select each line segment
depending on your emboss.
IV2009-Pro Sp1
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 174.06 Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
wrote in message news:6028212@discussion.autodesk.com...
annoying.
Thanks!
Ben
IV 2009 Pro
IV2009-Pro Sp1
XP-Pro, sp3
annoying.
Thanks!
Ben
IV 2009 Pro
Like this, the text was "ABS" and I have only
selected the later half for suppression.
IV2009-Pro Sp1
3.2
XP-Pro, sp3
174.06 Direct3D
3.12
IV2009-Pro Sp1
rpm
XP-Pro, sp3
SpacePilot Rel
<Koomler> wrote in message
size=2>news:6028212@discussion.autodesk.com
size=2>...
the prints
that require
fabricator
rid of the
does anyone
kind of
annoying.
Thanks!
Ben
IV 2009
Pro
IV2009-Pro Sp1
3.2
XP-Pro, sp3
174.06 Direct3D
3.12
IV2009-Pro Sp1
rpm
XP-Pro, sp3
SpacePilot Rel
size=2>...
the prints
that require
fabricator
rid of the
does anyone
kind of
annoying.
Thanks!
Ben
IV 2009
Pro
