How do I place the constrains for this setup?
FacebookGroupMember
Message 1 of 8
FacebookGroupMember
Hi, How do I place the constrains for this setup? I want the roller to follow the ramp of the rail, and the straight part of the rail. Greetings Davy
Replies (7)
Message 2 of 8
FacebookGroupMember
Use a transitional constraint.
Message 3 of 8
FacebookGroupMember
Matt Winyard only the transitional constraint?
Message 4 of 8
FacebookGroupMember
Make a New part and create the same loop as te rail. This must be a (surface) loft. Constrain This surface on the rail. And Constrain the wheel with tangent To the surface. Done
Message 5 of 8
FacebookGroupMember
Davy De Cock yeah. Select transitional then select the roller and the surface. You’ll obviously need to add a few more to keep it central to the path but that’s about it
Message 6 of 8
JDMather
Attach your assembly >>here<< if you can't figure it out.
Message 7 of 8
mcgyvr
Mate constraint face of roller flange to side of "ramp"..
Transitional Constraint rolling face of the roller to edge of "ramp"
Message 8 of 8
FacebookGroupMember
Try transitional constraint.
