How do I identify the inputs to recreate a 3-point plane?
SEC_CAD
Message 1 of 9
SEC_CAD
When modifying my part I keep a backup copy for reference.
Edits in the new copy may break a 3-point plane so that it needs to be redefined. If the original 3 points are not used then sketches on the plane can move.
How do I identify the original 3 points in my backup that were used to create the 3 point plane?
Replies (8)
Message 2 of 9
chenj
Hi, you can try right clicking on the work plane and selecting "Show Inputs",as shown in the figure below.The three previously selected points are displayed on the model.
Message 3 of 9
SEC_CAD
Thanks Chenj,
That seems quite intuitive and is what I did but I did not see any points highlighted.
Sorry - cannot share proprietary file but here is a demo with the same result.
My demo uses draft angles and filleted edges.
Message 4 of 9
Gabriel_Watson
Right-click the plane > Show Inputs. If it was defined initially by 3 points on creation, it should highlight those then.
Message 5 of 9
SEC_CAD
Please read above post. I did exactly that and the inputs do not show.
Message 6 of 9
Gabriel_Watson
Sorry, my browser had not updated to see the replies.
I was able to open your sample and I see your plane is defined by the center points of those fillets. Because Inventor is for some reason incapable of showing those kind of inputs, I would recommend you use this workaround:
1- drag your End-Of-Part marker up to a point before the fillets are created, and pick the corners for plane creation;
2- drag the EOP marker down for the full model to generate itself again.
Hopefully this method can be applied to your production model as well.
Message 7 of 9
SEC_CAD
Thanks. That is easy on a short demo but impossible on a large, real-world, example.
Message 8 of 9
chenj
Maybe you can use another method, first create 3 work points, and then create a work plane based on 3 work points.
Message 9 of 9
johnsonshiue
Hi! I would say this is more like a bug or incomplete implementation. The input geometry should be shown. I guess the only thing helpful is probably Relationship command. Right-click on the work plane in the browser -> Relationship. The parent features will be listed. However, it does not how the exact source geometry of interest.
Many thanks!
Software Test Engineer
