Inventor Forum
How do I create this curve?
19 REPLIES 19
Message 1 of 20
901 Views, 19 Replies
I'm struggling to create to create a corner curve. I've looked into creating freeform but I don't know enough about it to use it. Can anyone give me any tips or methods of getting this curve?
Below you can see what stage I'm at with the design and a image of the part.
Labels (2)
19 REPLIES 19
Message 2 of 20
long0212le
Create 2 sketches on 2 planes, then use Loft -> cut
Message 3 of 20
JDMather
Attach your *.ipt file here.
Message 4 of 20
in reply to: JDMather
Please find attached...
Message 5 of 20
JDMather
Before I start to model this - do you have top, front and side photos of the actual object (as much as possible perpendicular to the faces rather than at an angle)?
I think this design process can be significantly simplified.
There are unresolved issues indicated in your sketch/feature history and underdefined sketches.
Message 6 of 20
Okay, please find attached...
Message 7 of 20
gmwi
To continue with your flow, you need to make surface patches and stitch them. I'm with JDmathis on making it a more refined build but this will help with what you've got.
Message 8 of 20
cadman777
Do you have scan data for it?
Or is it hand measured?
If scanned, can you post the data?
With scan data I would use work planes and surfaces, then Stitch to solid, then add holes and fillets & rounds.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 9 of 20
JDMather
in reply to: cadman777
The scan is already in the file, turn on the Visibility.
Message 10 of 20
cadman777
Thanx JD!
Unfortunately my Inventor 2010 can't read the newer file. ☹️
Can you split out the scan data and post just it in, say, OBJ or some other generic format?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 11 of 20
gmwi
Cadman, here you go.
Message 12 of 20
johnsonshiue
Hi George,
Like experts already mentioned, there are multiple ways to do this. The key is to make sure the geometry is precise. I see a few places with loose sketch. It will cause trouble down the road. Another thing to watch out is to simplify the geometry. The corner in this case is best model by an intersection and then a variable-radius fillet. Any attempt to mimic the curve can lead to over-complicated geometry.
Please take a look at attached part.
Many thanks!
Software Test Engineer
Message 13 of 20
cadman777
in reply to: gmwi
Thanx!
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 20
cadman777
in reply to: gmwi
@gmwi
Any chance you can get me the point clouds?
These meshes are an absolute mess!
They're not even quad meshes.
The scan is the foundation of the entire process in RE work.
I wonder who scanned this and what machinery they used to do it?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 15 of 20
Thanks for all your help guys! Much appreciated. Saved me a lot of time figuring out how to do it.
@JDMather @gmwi @cadman777 @johnsonshiue @long0212le @
Message 16 of 20
gmwi
Cadman, sorry no. That mess pattern is the only thing in there, no base points. I understood your reference to Rhino7 with the quad remesh function. That's a very helpful feature. Autodesk will probably buy that like they did the T-spline function. I'll upgrade my current Rhino to ver 7 so my cad kit of tools is a bit better. For reverse engineering, that platform is HARD to beat for the bang-for-buck factor.
Message 17 of 20
cadman777
YVW!
I'm curious if you still have the point cloud?
Also wondering what scanner you used?
Would you mind sharing the point cloud data?
I wanna see if I can make it in Rhino3D from the point cloud and transfer it to Inventor into a parametric solid.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 18 of 20
cadman777
in reply to: gmwi
@gmwi
No worries, but thanx anyway.
Yes, I agree, but I doubt McNeel would sell off their QuadMesh function to their enemy!
Have you ever seen Mesh2Surface for Rhino3D?
https://mesh2surface.com
I used it in the past and found it to be very good.
Those Slavs really know how to make a good program!
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 19 of 20
gmwi
I have seen it but not acquired it YET. I use the Rhino program with an portable CMM arm  and the force is strong with that one. I do reverse engineer in my design work and Autodesk lacks in that support. I've made idea recommendations but there's not enough push for that. They have some other programs but they are WAY out on the ROI.
Message 20 of 20
cadman777
in reply to: gmwi
Yeah, I used Rhino w/a CMM.
Works great.
Yeah, every scanning and RE software is WAY overpriced for what you get in return!
I think the reason is b/c they cater to the military industry which has unlimited funds to spend on things, as well as 'the good old boys club' that pads the invoices like you can't imagine. How can we little guys compete w/that kind of criminal syndicate? We can't!
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Technology Administrators
