- Mute
- Permalink
- Report
What happened to the loop measure tool in inventor 2020? I noticed this in 2019 also. I have seen posts (back in 2015) where users hoped to simplify a technique I had always used, where you have to create a sketch and project a surface (edges) to select a loop to measure. This does not seem to have been simplified, but taken away completely. I also have always used a loop measurement to determine a suitable O ring inside diameter, now cannot figure out how to do it at all. It looks to be included in with the area measurement on an "enclosed area". There inside and an outside edge loop on every plane surface. Which one are you giving me? How do I select the one I need? How many additional steps are now required to do this, or has it been taken away completely? A loop is simply the length of every curve or line connecting tangent to another until it returns to the same point, is that complicated? I have found no use yet for the "improved" and more complicated dialog.
