Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
You can try purge:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-8CE33874-BD45-4682-91CF-C91D69394B7E
My biggest ModelState is 140MB. Most are over 30MB.
Check in is slow because it go through each ModelState.
There seems to be some persistent leaks in the file you attached - that's what's causing the file size bloat even after you have deleted everything.
Do you have steps to reproduce this? It would help to narrow down the root cause.
-shiva
I was hoping you might be able to elaborate on how and what led to this file to be of this size? Did you start off with some fairly big part and delete several model states and on save, you ended up with still a fairly 10MB+ file size?
If so, do you have the original file and remember what you did to cause the corruption.
-shiva
Hi Shiva,
I just noticed that the time to do the check in to Vault increased substantially and I thought it was a problem with the network but today I noticed the file was much bigger than a couple of days ago. About what might have led to this, I make no idea! Regular modelling as usual. This file is a stripped version because the original did grown to about 40MB.
Unfortunately, I can't disclose the original file.
JVilhena
Thanks @jorge.vilhenaF6UQE
I will ask around to see if anyone has seen any corruptions like this. I am copying @johnsonshiue to see if he has seen anything like this. Typically, it would be very hard to fix any corruption without knowing the root cause. Having said that, I will ask around internally to see if anyone knows anything.
I have created a defect (INVGEN-78095) to track it. We will try to see if we can find the root cause. In the meantime, if you run into it again, let us know if you have any steps to reproduce.
-shiva
Hi Jorge and Shiva,
This particular ipt seems to suffer from multiple corruptions. First, there are quite a few FEA related files linked to the ipt. The linkage can be severed by using Links command (Tools -> Links). That only resolve the prompting issues. The main corruption seems to be with a bunch of wire bodies. These ghosted wire bodies are probably part of the 2D or 3D sketches. They are left in the file without any association.
I have seen similar behaviors before but I am not aware of the workflow leading to such corruption. The corruption could also be a side effect of fixing the crash without plugging the corruption. Though the corruptive conditions are tolerated, the corruption is saved back to the file.
Many thanks!
Hi Johnson and Shiva,
The deleting operations should have deleted everything!
Nevertheless, if both of you could provide me an email address I can send you the original file but I can't post it here in a public forum. Actually, I have another one even bigger that inflated quickly to 155MB.
Best Regards,
JVilhena
You can email the part to me: sundarsATautodeskDOTcom
I can try to delete everything in that part like you did and see if it causes corruption.
-shiva
It looks like there were several sketch entities leaked. Even after deleting all visible entities in the part, those leaked entities persisted which leads us to believe that the leak is unrelated to the delete. Unfortunately, without knowing the cause of the leak it would be very hard to fix the issue. If you do come across the leak, could you please send us the steps - that would greatly help find the root cause and solve it.
In any case, we cleaned up your file and I have sent it to your email.
Let us know if we can help in any other way.
-shiva
