How can I open JPEG file with AUTODESK INVENTOR 2020 Thank you.
Solved by gcoombridge. Go to Solution.
Solved by arron.craig. Go to Solution.
You can't open a .jpg file directly but you can insert one into a sketch. I assume you want to do the latter.
Creat a new sketch and click "Image"
Insert a JPEG into a part sketch?
Into a drawing is more complicated - I think you need to make a sketch symbol and insert it there.
