Hello, marked arc part, how can I make this part. I tried a lot but it didn't work. (İnventor)
Solved by SBix26. Go to Solution.
Model a coil/use bend part..
https://www.youtube.com/watch?v=7yw-tQy9VKA
@FacebookGroupMember wrote:
it's not going to easy and will take some work. \
Actually - it is easy.
Attach your attempt here if you can't figure it out.
Reply to Message - Autodesk Community
Johnson Shiue it does not happen with bending. because one side is tight helix and one side is loose
Attach your attempt here.
I don't want to say that it's easy, as in beginner kind of material, but it's certainly possible. If you can tell us the measurements you'd like to see, and what version of Inventor you're using, we can probably do what you want.
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
