How can I make this part?
FacebookGroupMember
FacebookGroupMember
Hello, marked arc part, how can I make this part. I tried a lot but it didn't work. (İnventor)
Replies (15)
FacebookGroupMember
coil on the path of the arc /
FacebookGroupMember
Michael Davis thank you.... I've tried. but it doesn't work. doing straight line. but there is no round part
FacebookGroupMember
it's not going to easy and will take some work. \
mcgyvr
Model a coil/use bend part..
https://www.youtube.com/watch?v=7yw-tQy9VKA
JDMather
Actually - it is easy.
Attach your attempt here if you can't figure it out.
Reply to Message - Autodesk Community
FacebookGroupMember
There are multiple ways to do this. You can create a straight coil or helical sweep and then us Bend Part command to bend it.
FacebookGroupMember
Or, draw the path in 3 separate sketches. Use a line profile and each path to create Twist Sweep surface. Lastly sweep a circle along the twisted edges.
FacebookGroupMember
Johnson Shiue I will try. Thank you. İ hope i can
FacebookGroupMember
Autodesk Community thank you. I will try
FacebookGroupMember
Johnson Shiue it does not happen with bending. because one side is tight helix and one side is loose
JDMather
Attach your attempt here.
SBix26
I don't want to say that it's easy, as in beginner kind of material, but it's certainly possible.  If you can tell us the measurements you'd like to see, and what version of Inventor you're using, we can probably do what you want.
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
FacebookGroupMember
Another way to do this is to create a straight coil surface. Use it to split a long cylindrical rod. You will get the helical edges. Then bend the rod. The edges will be bent. Then sweep a circle along the bent edges. Lastly use Delete Face (lump selection) to remove the bent rod.
FacebookGroupMember
Try this...
Make the coil straight. Then use the Bend command. Click on bend and hit F1 on the keyboard that will get you to Help for the command.
FacebookGroupMember
Bill Bogan thank you
