Inventor Forum
How can i link inventor projects to the cloud?
9 REPLIES 9
Message 1 of 10
andrew.v.flores
1183 Views, 9 Replies
andrew.v.flores
Im almost to the point where i am going to be building a PC for CAD but i still need to use my laptop to do CAD work in class. Is there a way to seamlessly link file updates without having to transfer new files?
9 REPLIES 9
Message 2 of 10
SharkDesign
You can try Autodesk drive:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
Otherwise, unless you are using vault with amazon AWS or something like, the cloud is not recommended for Inventor. I've seen a lot of issues on these forums related to it.
VPN is a better solution, but that won't work for school.
I've never done the cloud route, so there may be other people with better advice.
  Expert Elite
  Inventor Certified Professional
  Expert Elite
Message 3 of 10
gcoombridge
OneDrive works okay, there are occasionally issues but I do it for work periodically so study use should be fine. Just set your project up to save content centre files to a specified foler in your project (NOT to default C:\ location)
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 4 of 10
SharkDesign
in reply to: gcoombridge
SharkDesign
I've seen people complain about onedrive making files read-only and confusing Inventor, is that an issue you have experienced?
  Expert Elite
  Expert Elite
Message 5 of 10
gcoombridge
No, it's been fine for the most part. The only issue has been a particular heavily ilogicdriven assembly caused errors when ilogic-copied. It contained i-parts and these seemed to be the cause. It was a very preliminary design and I decided to place them in a compressed folder and investigate at a later date (which hasn't arrived).
Message 6 of 10
gcoombridge
It does map directly to a C:\ folder and I think this is the key.
Message 7 of 10
andrew.v.flores
Thanks! I’ll give it a try.
Message 8 of 10
johnsonshiue
Hi Andrew,
At the moment, Inventor is not able to make sense of cloud path. The best approach to work with cloud storage is to use Fusion Team. If you use any other cloud drive, you may want to map the location to a logical drive. From Inventor's perspective, it interacts with the logical drive unaware of what is happening on the cloud side.
Many thanks!
Software Test Engineer
Hi Andrew,
Many thanks!
Message 9 of 10
gcoombridge
The other issues is as far as I'm aware there isn't a check out/check in workflow. That means if you are working collaboratively with anyone you need set clear boundaries between parts of the project
Message 10 of 10
johnsonshiue
Hi! Yes, that is a great point. Most file-based CAD systems require a PDM system to help manage file ownership. To work collaboratively using Inventor, it is better to use Vault.
Cloud storage can be used also. But, you do need to have good design process and practice to ensure nobody step on other users' toe. Also, on a regular basis, it is better to run a Update Design task via Task Scheduler to ensure everything is up-to-date.
Many thanks!
Many thanks!
