Adding Frame Generator Members
derek.takeno2023
derek.takeno2023
I am unable to add new members to the frame.  I made a sketch, generated a frame, then edited the sketch.  New lines are shown in the image below.  However, when I go to edit it, I cannot select those new lines.  Is this not possible?  Any help will be appreciated.
Thank you
SharkDesign
It's difficult to see from your image.
Try double clicking the frame first to edit in place and then add them.
Also is your filter within the frame member dialogue set to select lines or point to point?
  Inventor Certified Professional
gcoombridge
If the sketch you have highlighted is the one you're trying to change, leave that one alone. It is automatically created as frame generator adds members. Whether you created the frame from a parts sketch or an assembly sketch edit that instead...
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
