How can I create an helix accurately ?
Message 1 of 9
I don't see how I can build accurately an helix, particularly to design the axis, without wedging it poorly with the mouse !!!
There is surely a clever method, but I don't find it.
Tx for your help.
Replies (8)
Message 2 of 9
MechMachineMan
3-D Sketch. Draw a helix. Create a profile at one end to sweep along it. Sweep it. Done.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
Tx for your help, but my problem is at your step 2 : draw a helix.
To do it, I get a pop-up to define the diameter, pitch,... but nothing about the axis, except something that I have to wedge with the mouse.
It's really very poor and totally unaccurate.
Message 4 of 9
JDMather
My opinion is to never ever use 3D sketch to create a helix.
Use Coil instead.  Much easier to edit. (I guess I should qualify above statement - I might use a 3D sketch derived from the coil.)
@ bernik.onrock What is the design intent?  More information is needed.
Post screen captures/images/urls/ipt file.  More information on design intent.
Message 5 of 9
WHolzwarth
I've made a separate template (2015 IPT).
Not perfect, but surely better than struggling with axis directions.
Walter
Walter Holzwarth
Message 6 of 9
Ok,
I see the idea, but it's incredible that a CAO program has such lacks about basic features.
The same to define accurately a point : except to add 2 or 3 dimensions in a sketch, I didn't see how I can enter the coordinates of point straightforwardly....
Message 7 of 9
WHolzwarth
Smiley Wink Yes, we can
Try this in an IPT:
-Start 3D Sketch -> Point -> Expand Draw arrow down -> Precise Input
If you move the Precise Input feature to Ribbon Main Panel, it pops up immediately when clicking Point feature.
Similar behavior can be set in 2D Sketch as well.
Walter Holzwarth
Message 8 of 9
JDMather
@Anonymous wrote:
...has such lacks about basic features.....
Tell me exactly what you want and I'll demonstrate the correct (and easy and parametrically robust) way to do it.
Message 9 of 9
All was in the title : I want to build a helix accurately.
The pop-up for helixes asks all the needed parameters to do it, except about the axis of the helix.
wh gives me a way to do it, with 2 external 2D-sketches and adding 2 dimensions, 3 sletches + dimensions if I want to stall also the end points of the axis.
Btw, tx too to wh, for helping too about the draw feature for entering coordinates of a point. I didn't notice it.
