Hi JDMather,
Thanks for your prompt response.
The actual model cylinder dimension
- Outer circle diameter 8.6mm
- Inner circle diameter 7.85mm
- Thickness of the circle 0.375 (0.36-0.39)mm
4.horizontal distance between centre to centre 8.6mm
- Vertical distance between centre to centre 8.6mm
This is a honey comb composite. On the top and bottom laminated with fiber glass tape.
I planned to do FEA by Nastran.
For FEA I need to model the cylinder as surface has a diameter 8.225 mm.
I need to see the load capacity ?
Rgds
