VIEW NOT UPDATING AND NOT SHOWING HARDWARE SOME PARTS IN INVENTOR DRAWING
jaskiratVPK8U
jaskiratVPK8U
Can anyone tell me why in inventor drawing views washers and nuts are not showing up. I have these in the model.
Is this something to do with green corner box in the drawing? Is the view still under process? What should I do?1.PNG2.PNG3.PNG4.PNG
check  to see if the washers and bolts in the assembly are not referenced files.
go to the assembly, right click on the part, click BOM Structure, and click normal/Default.
jaskiratVPK8U
Thank you for the reply. BOM structure is normal/default in the assembly.
johnsonshiue
Hi! I have seen this behavior before. It may have something to do with the process of removing tiny detail for performance purposes. Does the washer contain short edges or detail that may not be printable? Please feel free to share the files directly with me (johnson.shiue@autodesk.com). I would like to take a look and see if it is the same as our known issue.
Many thanks!
Software Test Engineer
jaskiratVPK8U
Washers and nuts are showing up when they are not hidden. See in below.
Another question I have is that when I change the view to "hidden line removed" and try to show hidden lines for few parts it show a message and converts the view back to "hidden lines" and shows all parts in assembly in hidden lines.
Johnson, I have sent you the files for washer and nuts.
johnsonshiue
Hi! Many thanks for sharing the nuts and bolts! But, I do need the assembly and the drawing files. The fasteners alone are not enough.
Thanks again!
lena.talkhina
Hello @jaskiratVPK8U  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
