Hole Table - Part No in Title
Cris-Ideas
Advisor Advisor
Cris-Ideas
How to put PART NUMBER in the title of the Hole Table on the drawing.
Cris.
Cris,
https://simply.engineering
johnsonshiue
Hi Cris,
Besides writing an elaborated iLogic rule, I don't think an out-of-the-box solution exist. You will need to manually enter it unfortunately.
Many thanks!
Software Test Engineer
A.Acheson
Hi @Cris-Ideas
Try this rule out and see how you go. Not tested now but it should pull the first views model document  part number iproperty into the hole table title for you.
Dim drawDoc As DrawingDocument = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim activeSheet As Sheet = drawDoc.ActiveSheet
Dim drawView As DrawingView = activeSheet.DrawingViews(1)
Dim modeldoc As Document = drawView.ReferencedDocumentDescriptor.ReferencedDocument
'Get the PropertySets object.
Dim propSets As PropertySets = modeldoc.PropertySets
'Get the design tracking property set.
Dim propSet As PropertySet = propSets.Item("Design Tracking Properties")
'Get the part number iProperty.
Dim partNum As [Property] = oPropSet.Item("Part Number")
activeSheet.HoleTables(1).Title = partNum.Value
Regards
Alan
