Internal Toolkit Error when exporting to .dwf.
len.krenzler
len.krenzler
Just recently I have an "internal toolkit error" when loading a .dwf exported by Inventor 2024.3.1.  This is only in the last few days.  Has anyone else seen this?
johnsonshiue
Hi Lens,
Does it happen to a particular assembly? Did you export using Vault Job Processor or Export to DWF in Inventor? If possible, please share the files in zip with me (johnson.shiue@autodesk.com) directly. I would like to understand this error better. I have never seen it before.
Many thanks!
Software Test Engineer
len.krenzler
Hi Johnson, yes it was a particular assembly. I finally found that it was one imported part (made of surfaces) that was causing it. Strangely, I deleted the part and put the same part back in and it was fine. OK now, thanks.
