Hole Pattern on sloped surface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all
Can someone please let me know where i'm going wrong. we have Inventor 2014
I have a Sheet Metal part rolled spigot with the front face cut on a 1:16 slope. We then need to drill a series of holes around is keeping all the holes 15 mm from the sloped face (Work Plane1). Each hole should also be drilled parallel to the rear face (XZ Plane).
as the hole pattern goes around the spigot the hole don't keep parallel to the rear face (XZ Plane).
I know you can use the fold/unfold but the issued with this is that in the top level assembly the Component Pattern would not would and I would need to insert each bolt.
I have attached the spigot and also an image of the top and bottom with the bolts.
kelly.young has embedded your images for clarity.
Cheers
Donald
