Good morning everyone,
I have spent some time looking for the best solution for the task at hand. And unfortunately - couldn't find a workable solution in Inventor. Yet to make that part in real world is not an issue, really. It can me made on a simple milling machine.
Attached are three parts for anyone who wants to have a look at it. IV 2018 files.
Part1 utilises a rectangular array for the holes. The holes follow the slop, but their axises are all tilted. They are not parallel to the XY plane. Except for the very first hole. As a result of it when the part is placed into an assembly - Pattern Components using Feature Pattern option becomes useless. All the bolts will be seating on an angle to the outer face, which is wrong. BTW - Inventor seems to ignore Tangent constrain of the bolt's face to the outer face of the part when using Pattern Components tool.
Part2 is done with Unfold/Refold command to get the holes axis parallel to the XY plane. It is achievable but after the refold Inventor is incapable to introduce a Work Axis to any of the hole. It is understood, since the hole gets deformed. 3D Sketch comes to the rescue in order to create some auxiliary geometry. What I can not understand is - why the Point in a 3D Sketch is still green while it is constrained to the middle of the line? What other degree of freedom does that point have? Besides - I couldn't figure out how to Pattern Components in assembly using Feature Pattern option. It is just not there.
Part3 is done in old fashioned way. All the holes are parallel to the XY plane. Naturally - on the flat pattern they are all ellipses - but that's expected. There is no problem with constraining bolts to any of the hole but editing the part will trough the assembly constraints ballistic. Not to mention that creating that part in Inventor is a pretty tedious task in the first place.
The idea of using a 3D spiral for the Hole Pattern direction is not practical either. While the holes are parallel to the XY plane - the vertical distances from the slopped edge are all over the place.
That's all I can say about that part for now. Comments are welcome.
Cheers,
Igor.
Web: www.meqc.com.au
