Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Hole pattern call outs - Drawing
2 REPLIES 2
7670 Views, 2 Replies
We create a lot of cylindrical parts that have bolt hole patterns on the faces in a circular pattern. Is their a way to get the bolt circle called out? See image if unclear. This would help us out HUGE!ARC20842-CP.jpg
2 REPLIES 2
brendan.henderson
I don't think the PCD can be added by default as it's a custom sketch or placement feature you make at the part level which isn't available as an iProperty in the Hole Note. But much of the other data in your hole note can be by editing the Dimension Style and customising the correct Note Format to your liking.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
mercerc
Following on to the earlier post. I also tried several different options and methods to import or create the type of note you wanted. Other than adding like the qty of holes there was not an easy way I could find to get the bolt pattern diameter. You could post this to the Inventor Customization discussion group to see if anyone has created one using iLogic.
But this would make an even better suggestion to the Inventor ideastation so it can be addressed in the product. Please just the link here. http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Charlie M
Inventor Product Support Specialist
