We create a lot of cylindrical parts that have bolt hole patterns on the faces in a circular pattern. Is their a way to get the bolt circle called out? See image if unclear. This would help us out HUGE!
I don't think the PCD can be added by default as it's a custom sketch or placement feature you make at the part level which isn't available as an iProperty in the Hole Note. But much of the other data in your hole note can be by editing the Dimension Style and customising the correct Note Format to your liking.
Following on to the earlier post. I also tried several different options and methods to import or create the type of note you wanted. Other than adding like the qty of holes there was not an easy way I could find to get the bolt pattern diameter. You could post this to the Inventor Customization discussion group to see if anyone has created one using iLogic.
But this would make an even better suggestion to the Inventor ideastation so it can be addressed in the product. Please just the link here. http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
