Hide Tolerance On Thread Callout
cstarker6VCG4
Message 1 of 8
cstarker6VCG4
I need to hide the tolerance on thread call-outs by default.
I checked Style and Standard Editor and found nothing.
Any help would be appreciated.
Replies (7)
Message 2 of 8
ampster40
Sorry nothing to add but at least for imperial I do not recall seeing thread tolerances appearing by default.  Almost seems like somebody set that up locally but then maybe metric defaults are different.  Do you have anybody local that could possibly have tweaked your Inventor settings?
Message 3 of 8
cstarker6VCG4
Yes, our styles were setup as custom by somebody. That person will not respond to questions regarding this so I need to figure it out on my own.
Message 4 of 8
Frederick_Law
You were close.  Need to dig deeper.
Turn off "Use Default".
You need to change EVERY style with "Thread" in it.
Remove the "Fit":
And you need to do that to EVERY dimension style.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-3544F804-7FCF-45F2-AEFE-043CC9580C44
Message 5 of 8
cstarker6VCG4
I removed <THRC> from every Note Format and nothing changed. I assume that was the wrong variable?
Message 6 of 8
Frederick_Law
Took a while to figure it out.
Message 7 of 8
cstarker6VCG4
More like: Inventor is so ravaged with poorly thought-out "features" that I have to address them on a triage basis.
Message 8 of 8
cstarker6VCG4
This was a no-go. Removing <THRC> took thread direction with it. Did Autodesk combine tolerance and direction into the same variable? Please, let this be a nightmare.
