Helping in Modeling
Helping in Modeling
Helping in Modeling
I'm new with inventor 2017. I can't modeling this part in that is in attached.
Any body can model it for me?
JDMather
Can you attach the *.ipt file of your initial attempt?
Binga
There is some missed dimensions. But you can guess them:
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Curtis_Waguespack
Hi Mirza1ghasemi,
Here is a real basic start to the part, no attempt was made to follow the drawing dimensions, but it should give you an idea of how to get started. If you get stuck reply back and attach you file.
Keep it simple:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
@Curtis_Waguespack
Thank you for your Great video,
How can I make and insert video like you?
JDMather
http://screencast.autodesk.com
It's Free!
