Help with shelling
Help with shelling
jwill872
Observer Observer
Message 1 of 8
Help with shelling
jwill872
Observer
Observer
Hi
Can't get the shell command to work when I apply fillets to the gun handle of the model I'm trying to create
Works without the fillets
Any ideas?
* Am I not able to upload the file?
Replies (7)
Message 2 of 8
JDMather
I would not expect that part to logically Shell.
I think you are attempting Shell at the wrong point in the construction of the geometry and does not match the real world.
There is currently an issue with uploading files.
If you Edit a reply - you should the be able to Attach.
Message 3 of 8
jwill872
Observer
Observer
Ok - So you're saying I should rough out the basic shape first, then shell it, and then add more features later
Message 4 of 8
SharkDesign
I was going to make a joke about gun shells, but it probably would have backfired...
  Inventor Certified Professional
Message 5 of 8
JDMather
What is your intended shell wall thickness?
Message 6 of 8
cadman777
!BOOM!
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 7 of 8
WHolzwarth
Here's an initial shape (2022 IPT)
Walter Holzwarth
Message 8 of 8
johnsonshiue
Hi! Ideally, Shell should be able to handle any input geometry. In this case, there is too much detail geometry created after Extrusion19, which causes the Shell to fail. Simply move EOP right under Extrusion19. The shell will work up to 2.75mm.
Many thanks!
Software Test Engineer
