Inventor - Sweeping geometry, incorrect taper
Message 1 of 13
I am trying to sweep a geometry across a path with a negative taper and it seems to be scaling the taper incorrectly. When I scale the geometry, it shrinks up and down fine, but the sweep taper seems to collapse an arc at the bottom. Is this just something to do with constraints? Because of the arc collapsing I cant taper it without a self intersection error.
https://imgur.com/a/M0Kw6ya
Replies (12)
Message 2 of 13
JDMather
Everything looks normal and logical to me.
Can you Attach your file here?
(There is currently an issue with Attachments -  you must Reply and then Edit Reply to see the Attachments button.)
Message 3 of 13
Thank you very much for taking a look. As you can see in the attached part, when this profile is swept across the path, it does not scale down properly to make a negative taper. The bottom radius collapses too much.
Message 4 of 13
JDMather
@Anonymous wrote:
...it does not scale down properly
How are you making this determination - there are no dimensions on Sketh24 and I suspect that you are missing intended Tangent constraints?  Where are your dimensions?
What is your Design Intent?
Message 5 of 13
WHolzwarth
I didn't look at the initial sketches of the sweep, and regarded them as fixed.
But doing a tapered sweep along 3DSketch15 is only possible with a limited taper angle. In this special geometry it's possible up to -1.3 deg.
2021 IPT attached.
Walter Holzwarth
Message 6 of 13
JDMather
@Anonymous
Examine the attached file.
I laid out your Sweep Path arc as a straight line.
What do you observe?
Message 7 of 13
Thank you all for your comments. JDMather, the file you attached for some reason only showed a semicircle, but what I did is I scaled my geometry on the same plane as the sweep geometry ends in. In the image, my goal is outlined in green, a smooth linear scaling of the whole profile. What happens is overlaid and the bottom curve collapses strongly. It seems like this has something to do with constraints but I cant figure it out.
Image here: https://imgur.com/a/3q4YnDi
New IPT attached.
Message 8 of 13
JDMather
New IPT attached.
I reduced the geometry to only the arc to help illustrate the problem - this is basic geometry - you scale something it gets smaller (or larger).
It has nothing to do with constraints.  Simple geometry.  Not sure why you Attached a second file - same problem.
Are you a student?
Is this a class assignment?
I know the solution to your problem - but I am trying to help you arrive at the solution in a logical manner.
Message 9 of 13
Thanks, I still cant understand while the SCALE function drops the size linearly while the SWEEP function drops the size of the bottom radius more rapidly compared to the larger radius. I am a hobbyist, I would appreciate any tips for how to draw this geometry so it scales properly. I have tried using arcs instead of circles, etc. Same result.
The new file I attached has the overlay of the goal shape compared to the taper, same as the image in my last post.
Message 10 of 13
BDCollett
I believe what you actually want is a Loft using the 3D sketch as a center rail.
Sweep is only using the one shape and your taper is too much to achieve the result you want.
To do this you will need to fix your sketches up first. They are broken and unconstrained. Try and make sure all sketches are constrained before creating features. You can see in the bottom right corner how many dimensions are needed.
Message 11 of 13
The loft will not work because it is swept across a 3D line and seems to twist in a strange way, that is why I switched to sweep.
The core issue is that during the taper, the profile does not scale linearly (bottom radius scales more than the top radius).  It must be because of the way I drew the profile, but not sure how I could do it better.
Message 12 of 13
JDMather
Loft will work if done correctly.
Message 13 of 13
johnsonshiue
Hi Nikita,
What you are asking cannot be done by using Taper Sweep. What Taper Sweep does is to taper the sweep face inward (or outward depending on the taper angle) along the path. So the arc profile segment with a smaller radius may convert to a point sooner than an arc with larger radius.
You may need to increate the profile radius. Or, simply remove the rounds from the profile. Next, create the Taper Sweep. Apply desirable fillets afterwards.
Many thanks!
Software Test Engineer
