Help with roundToNearest() math Function in parameter
Jallen_USBattery
Jallen_USBattery
I am designing an assembly that uses linear rails that are ordered in lengths incrementing by 25mm.
I am trying to get Inventor to round a parameter to the nearest 25mm using the 'roundToNearest()' math function but everytime I try to use the function Inventor throws a fit and says it cannot parse equation...
Note: I have also tried adding a "(equationhere) x 1mm", to see if it was because roundToNearest might be a UL function but that didn't help either...
Link to 'roundToNearest()' math function:
https://help.autodesk.com/view/ETOCOMP/2020/ENU/?guid=GUID-6DDEEF80-5964-406F-99A6-C982BB508607
Screen Shot is attached for what I am trying to do and the error I receive
Can someone please set me straight on this??
Thanks in advance
pcrawley
The help file you've linked to is for "Inventor ETO" 2020 - which had some iLogic-like programming capability, and "roundToNearest()" was one of those functions.  It's not a standard Inventor Professional function.
Try this for Inventor:
To save you typing:
round(round(Length / 25 ul) * 25 ul)
roundedLength * 1 mm
Hopefully obvious - change the "25" in the equation if you want to change the increment.
Peter
Alexander_Chernikov
hi, try the following formula for parameter
round(round(Z_LinearRail_Length / 1 mm) / 25 ul) * 25 ul * 1 mm
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Jallen_USBattery
Thank you Alex & and PCCrawly, i eventually ended up doing exactly this. Just wish it was more clear that ETO wasn't native to Inventor. Now I know I guess.
Thanks for the help though!
