- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I use inventor professional 2018, I use a computer i7, 32 GB Ram, nvidia Quadro P200. But I haven't been able to create a slot perforated cylinder that I really need to represent in al the drawings and 3ds. I upgraded the video card drivers but it still not realizing the path process.
additional info:
my motherboards is Z170A Gaming M5
case is a Cooler master. and a cooler master for the microprocessor. So why it does not process? (i mean if it will take 2 days its the same as if doesn't process as I think no one will wait that long) those are around 2500 perforations in the cylinder. and I have another with the same amount but the perforations are shaped, so when I tried that the computer just got stocked thinking. Is it something I can do to realize this mechanical process with inventor?
In the picture, you see some perforations done, it took about 40 min to do this, but I need to fill that cylinder with those perforations and I need to perform another perforations that are even more complex.
